Fixing End Moments
After completion of the run, I got Von Mises and displacement values.
Is it possible to ave the fixing end moments and reactions at the supports?
Thank you,
Robert
Hi Robert,
You can compute the reaction forces using a Result control item - Area calculation - Sum - Force - Reaction, and assigning the faces with restricted movement:
Unfortunately, it is not possible yet to compute reaction moments in SimScale, as the feature is under current development. You can achieve this by downloading the results and using a tool such as Paraview to compute the moments.
Thank you so much for the prompt reply.
