Received those meshing error in the F1 first tutorial:
2016-03-24 11:03
Illegal triangles were found after surface tesselation. There could be a problem with the CAD geometry. Trying to proceed anyway.
2016-03-24 11:03
The tesselated surface is not closed. There could be a problem with the CAD geometry (such as self-intersections). Please inspect your geometry. Trying to proceed anyway.
The meshing has been already running 45 minutes, not completed yet. Should I be concerned?
Further, I think you don’t have to worry about the warning/error message you received. It’s quite common for more complex geometries – the ones with more complicated surfaces. What you should take a closer look at though is this part of your meshing log:
