I created a Tet mesh in Simscale and I would like to export it to OpenFOAM to do the simulation.
What I did is:
-Download the mesh from Simscale (.med file)
-Open the .med file in Salome and create groups (inlet, outlet, walls).
-Export mesh from Salome (.unv file).
-Open openFoam and use the command ideasUnvToFoam.
The problem is that when I use the command ideasUnvToFoam it gives me an error.
Have you converted the mesh with face groups? If so please try it without the groups and let me know if ideasUnvToFoam still throws an error. Here is a script that you can use for conversion: salomeToOpenFOAM with the corresponding Salome thread: Salome Mesh to OpenFoam.
I tried without creating the face groups and it works. And then to be able to define the faces ones I converted it to openFoam, what I did is to change the default names in the file boundary.
