My simulation runs are quite huge in size and I don’t want to download all the data but only want pressure values. How can I do that? Thanking you in advance.
Hi, this is Fillia. Do you wish to obtain the pressure data for a specific point or surface for example?
I haven’t used probe points but yes, I would like to download the data for the pressure at a certain point. Is there a way I can do that?
Sure, check this page on the ‘Result Control’ : Result Control | Simulation Setup | SimScale
You can extract the flow parameters on a probe point that you set prior to the run
