I am applying a force along +Z axis in harmonic analysis and that is the only force applied, and I am trying to see displacement of a given point.
The result shows different values for displacement real Z and displacement real magnitude.
I was wondering how they actually defined in SimScale.
Hi, and thanks for using the forum.
Can you please also share a link to your simulation so I can have a complete look at the situation?
Thank you for your reply.
Here is the link:
It is Simulation run 8.
Hi, and thanks for the link.
This seems to be a bug in the written results. Notice how only the DX component is reported in the point data results. I will report this to the team as a bug.
As a workaround, I would suggest to create separate point data items for each DX, DY, DZ components.
Thank you and I think I understand what you are referring to after adding Point data separately for Displacement X, Y, Z.
Two questions:
- Is the unit in the plot of displacement under Point data inches?
- Is the value in the plot of displacement (magnitude) the absolute value of the max. displacement in either direction?
Hi!
To answer your questions:
- The units are reported in the plot, typically it is in meters. To convert to inches, you can download the data in CSV format and use a spreadsheet program such as Excel.
- The value reported is the amplitude for the degree of freedom, assuming the harmonic motion. It can be interpreted as the max displacement in that direction, as you mention.
