Hello, I am trying to run a conjugate heat transfer analysis on a water tank using derived heat transfer coefficients and temperatures applied on the external wall. I am interested to run this analysis as transient since the derived heat fluxes change over time however, even though I have set the analysis type to transient, there is not an option to have a table with time vs heat transfer coefficient and ambient temperature.
Would it be possible to perform this analysis in Simcale at all?
It appears that the following settings in the wall boundary condition allow for inputting heat fluxes as a function of time:
Temperature type->External Wall Heat Flux
Heat Flux->Fixed Heat Flux (Click on the table icon to manually input different heat fluxes over time or to upload a csv file)
The heat transfer coefficient can be calculated using Result Control.
