Continuing the discussion from I'm not able to start simulation:
I would like to rotate the camshaft with a rotational motion and then measure the heat generated on the drivers. How can ı do
Hey! To rotate the camshaft and measure the heat, you’ll need a rotational setup and temperature sensors.
