Hello.
Im making a simulation of a propeller but I cant create saved selections, before I created flow region and rotating zone but once it saved i cant select the propeller and atmosphere, so I try to select the faces of the gap in flow region but when i run simulation i have errors.
How can I solve this problem?
Hi @jformoso,
Thanks for posting on the forum and welcome to the SimScale Community
In order to create saved selections, you need to select the desired faces and click the following option:
Maybe you’re also having a tough time selecting surfaces because of a lack of familiarity with SimScale’s UI. Here you can find some tips and tricks on the viewer.
