Hi there This is probably because some faces belong to more than one region (as they are in contact).
Maybe you can create your external flow volume in a way that it is not touching the edge of the 3D printer?
If anyone else has a suggestion, feel free to contribute
Thank you for your help, i was able to run the simulation but, i have another problem.
I think that i didn’t choose the right boundaries, you see i calculated that I should have a temperature of at least 149°C (422°K) at the edge of the steel’s faces, but when I look at the results it shows 85°C (358°K) for the hottest part.
I try to turn of the boundaries of 20°C on the outside flow region that is surrounding the printer and adding a natural convection of 150°C to the flow region inside but when I try to launch the simulation I have this error.
I noticed that you are currently running the case as a transient simulation. Is this a requirement for your analysis? Or would you be interested in the equilibrium state of the system?
Furthermore, as the documentation page that I linked states, defining a boundary condition to an interface (i.e. the interface between two volumes) overconstrains the system and causes the error that you are facing.
In short, the only faces that can receive a boundary condition are the boundaries of your geometry (i.e. the 6 external bounding box faces of your flow region). The other faces cannot receive a boundary condition.
I’d suggest that you go through the LED natural convection cooling tutorial, which should provide you good insights with respect to the set up.
