How to combine Fluid analysis with FEA
Hello!
Can you please expand a little bit more on what you are trying to achieve? (Application, objective, etc)
Hi sir, i am trying to do an aeroelastic analysis meaning that i will run an incompressible simulation and use the simulation result (pressure) as a boundary condition to perform a FEA analysis. this is a video to illustrate (https://youtu.be/Yv6y8B_BVPk?feature=shared)
You can currently run 1-way FSI simulations in SimScale by:
- Running the CFD study first
- Downloading the results and opening them in ParaView
- In ParaView you can export values on surfaces (File > Save Data), which will contain X/Y/Z coordinates and pressure values
- Use this table for a table definition of a pressure boundary condition (now for FEA)
- Run the simulation
2-way FSI is currently not possible, in case you are aiming for that.
thank you sir
