CHT - Temperature/ Heat source issue
I am analyzing heat transfer of a battery pack through. A heat source of 2.75w is applied per cell.
when the simulation is completed, there is barely any change temperature.
Can anyone help me regarding this issue?
Project link: SimScale
Thank you
Hi there, this is Fillia :slight_smile:
There is some temperature change, of course, it is not significant, but if the conditions changed, you would see a greater difference.
I have a couple of comments:
  1. Have you checked whether the flow is actually turbulent?
  2. Try to increase the dimensions of the domain across the y-direction. You can use Figure 8 from this tutorial as reference: Compressible Flow Around a Wing | Tutorial | SimScale
  3. If the domain does not represent a closed box, switch the “No-slip walls” to “Natural convection inlet/outlet”.
