I would like to calculate the mass flow through a slice of my solution field in Paraview.
Any tips on how I can do this?
@Filiptheking, this seems to come up quite a bit on the forums. @jousefm, we might wanna include this in a post processing wiki in the future, possibly with the theme of âIntegrate variableâ filter.
The volume flow rate is the normal velocity times the area, and the mass flow rate takes into account the density as well. This is pretty straight forward, but translating it into paraview filters takes a bit of thinking about but essentially comes down to these steps.
The result should be a single value in the table.
Good luck,
Darren
Hello @1318980 ,
I think I managed to get a value for the flow.
Here is what I did:
Is this the right approach?
Should I convert cell data to point data before the integration? I get slightly different results if I do.
Never tried that one, I normally go with the âGenerate surface normalsâ filter but it sounds like this should give equal results.
Seems right to me
Think its more accurate to do it on the cell data, as the continuity is on the raw data.
Thanks for sharing!
Darren
That seems reasonable, thanks @1318980!
I tried both the âsurface vectorâ and the âsurface normalâ-filters and got exactly the same result when I integrated. However, I notice that it was difference in to coloring of the surfaces. The reason behind this seems to be that the âgenerate surface normalsâ- filter didnât really generate vectors perpendicular to the plane. Why could this be?
Surface vectors, color plot
Surface vectors, glyphs. Notice that the vectors are perfectly perpendicular to the plane
Surface normals, color plot The coloring outside the circle is a little bit brighter than the surface vector-plot
@Filiptheking Did you figure out why the vectors generated by surface normals are tilted? I am also interested in the same issue.
I still donât know unfortunatly. Hopefully someone else can answer this. Would be nice to know.
Hi @Filiptheking @jovenitta, not sure I am seeing the same thing. When I apply a âGenerate surface Normalâ I see as I would expect (all normal to the surface) if I use âSurface vectorsâ I am asked what vector I want and whether or not I want to project it normal to the surface or perpendicular, this is similar to doing it manually in the calculator using dot product. However, I see anomalies here, using vector normal, where zero values of velocity (i.e. at the walls) obviously cannot correctly be projected and become a bit weird.
Darren
Also Whilst looking at this found a 1 step filter called âsurface flowâ it basically does the integral of the dot product between a vector (velocity) and surface normals and returns it in the paraview spread sheet. This saves alot of time.
Darren
Hello, to calculate the flowrate over a section in paraview please check this video:
Hello Filip,
I also need to come up with the volume and mass flux on specific surfaces in my simulations. I have one question, which does not seem to be addresses in the original inquiry of yours, and that is, how to bound the integration on a certain area inside the slice? In other words, I have a surface with the crossing vector of velocity through that and now want to calculate the volume flux inside the area in which the velocity is smaller than a certain value.
I have a question how the âintegrate variablesâ filter works. Does it return the corresponded value times to the area on which the âsurface vectorâ has been applied. In other words, your third statement , "integrating the normal velocity ⌠" already assumes that the integration is handled by integral (U_normals*Area)?
Thanks for sharing!
Darren
