Boundary Layer Does Not Form - Except When Default Settings Used
Hi @cweisheng,
Deletion of layers is due to the quality controls of the mesher. Earlier in this thread I believe I posted the link about layering in SimScale and one of the troubleshooting steps to prevent layer deletion was to decrease the quality control. I’m sure you have done that before as well, is that setting still maintained?
Yes this is also a possible issue. If what I mentioned earlier does not allow you to generate the % of layers needed, then do add a region refinement around that area. That should help in layer generation, but by how much is unknown.
Refer back to my first comment. Yes this is usually the case for layer deletion.
This should not help that much. As mentioned it is the quality controls likely deleting off your layers.
