Average values of all available parameter in "Result control" feature
Unfortunatly, at the moment user controls only limited number of parameters via Result control feature: Ucoord, p, k, epsilon:
But for heat transfer case or scalar transport problem it would be better to have a temperature and scalar control at the outlet boundary respectively to see how it converges or changes with time.
So please consider to add control of additional variables to the Result control feature.
Hello @varsey,
we already had multiple requests for both points that you mentioned.
  • Adding the missing solution fields for the current face average result control items
  • Adding probe points
Thanks a lot for the input. It helps very much in prioritizing!
Best Alex
Thanks for responce!
@varsey missing fields issue is fixed. Will be available in the upcoming update.
