Hello, i’m a beginner on Simscale so i hope the problem may be easily solved with some help.
I’m working on the following project: “essai dynamique - Copy”, it’s in public mode.
When i look at the results of the simulation “Run 6”, i don’t understand why I can’t see the “Von Mises stress” (and any other physical quantities) on the solid “Part 3” (the one that looks like a sole).
Can anyone help me?
Thanks a lot.
nico
Hi @ndeli,
Thanks for posting on the forum
Always make sure to attach the URL to your project when posting here!
I’ll investigate your project and get back later with my findings
Hi @ndeli, I just wanted to reach out again to provide some follow-ups
Looking at your model, the EVA you defined seems really soft (the values for \mathrm C_{01} and \mathrm C_{10} look pretty low). Where did you get the values for these parameters:
One possibility would be that they are in the wrong units. Could you check that?
Thank you for your quick response @igaviano .
Eventually I was mistaken on the units and i corrected it (Pa to kPa), I had these values experimentally. However, as you can see even when I changed the units the problem persists [essai dynamique 2 - Copy by ndeli | SimScale].
Do you have any other idea to solve it?
Thanks.
Nico
Hi @ndeli, sorry for the late reply here,
As I see it, you’re only facing a problem in the visualization of your results, changing the legend bar’s limits makes it possible to visualize further details on the sole:
This happens because the stresses on the sole are much smaller in comparison to the ones in the other solid bodies.
You can check a workflow on how to do that here.
