I have a really naive question - when I view my simulation results, I can see the displacement in a colored heatmap but I cannot see the actual deformed shape of the geometry. How can I see that?
FYI - the project is SimScale and it is the “Simulation 2” that I was looking at.
the “Warp by Vector” filter in the post-processing environment will do the job. Simply apply it on your result field and you can then visualize the deformation field via an actual deformed geometry.
It maybe me running the simulation wrong, but when I run my uniaxial tension of a elastic-plastic material, the deformed body looks very problematic. I went into my SimScale , went to simulation 2, solution fields, added WarpByVector to displacement fields.
I have a few years experience w/ ABAQUS and ANSYS but have never used Code_Aster or Salome-Meca before, so it could be just me not being familiar with SimScale’s solvers or postprocessers. I’ll try to figure things out, and any feedback would be really appreciated
What is the material that you are assigning? You have a very low Young’s Modulus assigned (E = 724 N/m2) - for Example steel would be E = 200e9 N/m2
Also for the displacement you are applying, I would rather recommend a “fixed value” BC. Consider the value of displacement that should be applied - by setting dx to 50, you are applying a displacement of 50 meters which is why the deformed shape looks odd.
@saienrugdeo was doing a similar project a while back and his project might help you with the setup of your own analysis
It is pretty simple, just go to "warp by vector"and then click on desired “Field (von-misses stresses/deformation)” and also add “opacity” as seen in the picture.
As anna pointed out, an Youngs modulus of 754 N/m^2 is very low compared to other materials like Al, Fe etc.
Hope my suggestion on warp by vector was helpful.
Cheers !
Ah - thank you! I was having the old habit from ABAQUS and using the unit-free numbers. Unfortunately, I guess the OnShape geometry import has automatically converted mm to meters, so I should also convert my 724 MPa to 724e6 Pa (it’s a polymer) and the distance should be 50e-3 = 0.05 m, instead of 50.
Thank you again for your time - I really appreciate it. And also I appreciate your sharing of the similar project. I’ll fix it and give it another shot!
indeed, you currently don’t have explicit control about how units found in the CAD model should be treated. Providing more control over units when importing CAD models is on the roadmap. If you’re envisioning a specific way of doing this, feel free to share it in the Vote for features section!
I have a new question wrt. this project (and please let me know if I should open a new thread): I ran a simulation with reaction force in the output request (added it to the “Solution fields” in the “Solution control”). However, when I came to the post-processor, I do not know how to plot the reaction force over time. I can color code it as if it were stress fields, but obviously this is only suitable for observing field distribution like stress, instead of force over time. I know there must be a way to do it - could you kindly share a pointer to related documentation? Optimally, I’d love to learn it in both the online post-processor and the offline paraview.
Hi @yw5aj,
there are several ways how you can do that.
Online: In the result control in addition to the solution fields where you added the reaction force, there are items called edge-, area- and volume calculation as well as point data. All of those create plots from some processed data (sum, min/max, average) on the specified entities. There you could add an area calculation on the fixation faces and compute the sum of the reaction forces, the total reaction force. This will create a plot with the reaction forces after the calculation is finished. Unfortunately at the moment you have to re-compute the full calculation to add such a plot after the initial run was finished.
Here is the corresponding documentation link: SimScale Documentation | Online Simulation Software | SimScale
And a related forum post by @ahmedhussain18 where those items are also explained: [Result Control] Calculation methods on specific entities and their differences
And a public project by @BenLewis, where several result control items have been used to compute, amongst others, the reaction forces[!!!THIS LINK IS NO LONGER AVAILABLE!!!]
Offline: In local ParaView there are several ways how you can do that. For example you can use the extract blocks filter to reduce the computation to only a part of the model (fixation faces for example) and then use a calculator filter where you can simply use the SUM operator to compute the total force. This forum conversation might also be helpful: How to get nodal solution results?
I am trying to add the “Warp by Vector” filter but I can not seem to find that parameter in the current Result Control, is there a new way to accomplish what the Warp by Vector filter did?
this is how you can show a deformed shape in the new post-processor:
But indeed, some of the capabilities of the new post-processor aren’t easy to discover - something we’re actively addressing at the moment! In the meantime, I hope above video helps!
David, am I to assume that a value of 1.0 on the slider shows the deformation at 1 to 1, slider at 0.1 shows deformation as 10% of actual and slider at 100 shows deformation as 100x exaggerated?
