Dear Sir,
I have no idea what I’ve done wrong to get this message for both my simulations.
I hope you can help
Dear Sir,
I hope you can help
Hello @varunsura ,
you have time until Friday. So feel free to finish your project by finishing your meshing and simulation setups.
If you have trouble finishing your project I will provide you with a version where you just have to finish the simulation setup.
Hi @hgibbons ,
that message indicates that your Simulation Control settings are such that your computational core hour quota would be exceeded during the run.
@AnnaFless might help you there.
If you want to finish your project I will run the simulation for you if you like.
Good evening @tdangi,
can you elaborate your question please? I am willing to help you
That would be amazing if you could. Do you need me to do anything in order to do so?
Harry
Just make sure you set the visibility to public so that I can copy your project into my workspace.
See also:How to share a project
Here’s a link to my project.
Thank you very much,
Harry
Hi @jousefm
As you told me to increase the cores and then rerun the meshing operation, so I did. And yes it worked, thanks for your help. Really appreciate it.
Regards.
Hello. My 18deg-5mm-up Mesh failed 5 times in a row. Can someone please check on it? I don’t know why it does not want to work thanks!
Hi @estephan,
I will send you a message with the project having meshed everything. Just make sure you set up the simulation settings
did you send it as an email? Then I have to check my mails.
I found it thank you. Shall I put this link in the homework submit form?
No @estephan. Finish the simulation setup. I just gave you the finished Meshes so that you can work on the rest and do not have to wait
I did them all. I started the simulations. Now I’ll have to wait
Greetings,
I would like to know if the homework will be accepted with 5 simulations finished since my mesh operations for configurations 4 and 8 finished in error again and my simulation for configuration 7 has finished without Solution fields. I will try to perform these operations again but in case they dont finish computing in schedule it would be possible to present only 5 simulations completed as stated above?
Best regards.
Hi @juansan995 ,
If you have any further questions please do not hesitate to ask.
Good luck and cheers!
3 of my simulations were cancelled due to i think the overloading of the server so is it okay if i upload the homework assignment as it is?
Hi @bmaitra,
as mentioned above you can just send your project with the meshing and simulation setups shown.
