@Get_Barried
I am following this tutorial ( Session 1 - TUTORIAL - Ride Height Analysis )where you can see that an even higher value of omega is used. Also I use the formulas used in this page ( K-Omega and K-Omega SST | Global Settings | SimScale ) . Finally to double check the calculation i used also the spreadsheet given in this link (CFD_Calculator_Formula_SAE - Google Sheets) that i found in this forum (Step-by-Step Tutorial: Homework of Session 2 - #173 by jbin). Thank you for your time!
