Hey,
I am doing a compressible flow analysis of restrictor applied in Formula student vehicle. And getting this errors
Tried to encounter errors which could be possible as provided in the link
by making residual tolerances to 1e-2 and mesh log is saying its all fine here .
Why not try to use the project of @jprobst as a template: Venturi Injector - CFD Analysis. Let me know if that helped to fix your iteration issue. If not I will have a closer look at your setup and jump in again
Thanks for replying!!
Its working fine when the settings in flow analysis type are set to incompressible.
But I have a physical problem with density variations and so need compressible analysis type setup. Which is still an issue.
Thanks for sharing the project âGuy is really Top Gun at setting up simulationsâ
Itâs really very helpful.
But I wanted to know that as per mentioned in Docs for 2D empty is it necessary this boundary condition or itâs fine to do without it
as now learning from Mr. sjoshiâs simulation trying to simulate by axisymmetrical conditions.
OpenFOAM has no other way to reduce dimensions so thatâs what you can use the 2D empty boundary condition (BC) for. But in your case you make use of the axi-symmetric nature of the model where you could either use wedge or the cyclic BC. Difference between both:
Wedge: for 2 dimensional axi-symmetric cases like your âcylinderâ with a small wedge angle \approx 1°.
Thanks for the insight
Tried to do 2d axial symmetric simulation, again working well for incompressible flow but facing same issues while simulating compressible flow situation.
Copied your project over and tried to play around with the boundary conditions to no avail. Iâll keep trying to see what I can do but hopefully someone with more experience with compressible flow can help!
Hi @ojagtap, increasing slowly to that flow rate will give the same results but will be a lot more stable. Make a .CSV from say 0 to 500s ramping from 0 to your desired flow rate.
Hey, @ojagtap!
I think you should use the âDensity-basedâ solver in the âcompressibleâ analysis type. I see that the current runs were with the âPressure basedâ solver which is not designed for such flows.
As of now, Simscale only has the âDensity-basedâ type available with a âLaminarâ turbulence model in the transient state. So you have to go with a Laminar assumption and try with that.
Hope this helps!
Hey,
Thanks for the advice @ronnie007 . I really think I need to change simulation to transient from steady as said by darren. As I was not getting option to set density or pressure based in steady state condition. And as I realised now âSteady state density based solverâ up for vote new feature.
Let me give it a try!!
Hi @ojagtap, just to clear my comment up I donât mean to change from steady state to transient, but to ramp the flow rate in the steady state. I use a steady state velocity ramp in this project for compressible simulation:
The same principle can be used for flow rate.
The density-based solver is much more stable and is currently only available in a restricted use case as above mentioned. Please vote here:
