Hello guys, I have been working on the drop analysis test of an Iphone. The simulation gets cancelled half way and shows ’ Instance storage ran out of space , try increasing write interval’ . I have tried doing the suggested ,please help me out sort this issue.
Sorry for the delayed response @aravindshajil!
This here might help you out: Instance Hard Disk Full | SimScale Documentation | Knowledge Base
Edit: Also reduce the number of nodes by making the mesh coarser! That can help.
This is actually a mesh that shows you how it should be done: https://www.simscale.com/workbench/?pid=1695724519638304175&mi=spec%3Aa49130fb-75e0-477f-b8ca-b02340fb8240%2Cservice%3AMESHING%2Cstrategy%3A210&ps=algorithm%2FTetDominant--oneOf%2Frefinements%2F2&sh=6 - props to my colleague @rszoeke btw. He also mentioned that your “Cover Body” is assigned for the mesh refinement but you will see in the linked project that only the contact surfaces should be assigned.
