Turbulent viscosity ratio = turbulent viscosity / molecular viscosity. For incompressible flow, OpenFOAM uses the kinematic version of viscosity. In this case you have kinematic viscosity ratio (nut/nu) = kinematic turbulent viscosity / kinematic molecular viscosity = kinematic turbulent viscosity / 1.5e-5.
The kinematic turbulent viscosity (nut) is calculated by the turbulence model. With each pair of k and omege values, you will get a unique nut.
I should have explained this better. The table on Dry Air - Thermodynamic and Physical Properties contains molecular/laminar viscosity only. The molecular viscosity is a fluid property independent of the turbulence models. The turbulent viscosity is the result of turbulence modelling.
The SA 1 equation turbulence model is adapted for flows around an airfoil and as you know boussinesq approximations to not behave super accurate (whatever you define as accurate in this case), but a contracting section is a good example as the eddies loose their identity along the way. And standard k-epsilon is by definition not realizable (need a separate post to explain what that means) so one usually uses realizable k-epsilon but fully developed pipe flow for instance work pretty well with standard k-epsilon. k-omega SST does a pretty good job and there is no need for SA model, what do you think?
I exclusively use SpalartAllmaras, RealizableKE, and SST as RANS. In fact, I find SpalartAllmaras very useful for external aerodynamics with mild separation, such as a plane or a wing. I think @DaleKramer’s problem can be very well solved by SA, because I have done similar projects.
Just curious as to why you suggest calculating ut/u from the cfd_online.com formula rather than from the Spalart and Rumsey recommendation of 2e-7 * Re ?
There is a 20% difference in my case.
And by the way, I did have to change my reference length from a fuselage length of 5m to a value of 2m to stay in your suggested ut/u range of 0.1~2. My ut/u value is now 1.89 (EDIT actual value is now 1.6182, see edit 2 posts down).
The 2e-7*Re is just an estimation. The actual nut calculated at inlet should return a nut/nu = 1.888 or much closer to 1.888. I don’t think a length scale of 2 or 3 will lead to much difference in Cd or Cl. It is safe to use what you have here.
Turbulent viscosity and eddy viscosity are the same thing. However, nut = mut/rho, where nut is commonly used in incompressible flow, and mut in compressible flow.
I hope you are doing well. I would like to know, is it okay if my ut/u ratio is equal to 0.1005 ? or Should I adjust any further ? My case is more or less similar, I am running a simulation of flying wing aircraft.
