I want to find out what the mass flow rate is at a certain face on my solid body. Is there any way to do this.
Kind regards,
Syed
Kind regards,
Syed
Hi there! Please check the solution of this post: SIDEPOD outlet mass flow rate - #2 by tsite
Thank you for your answer.
I am wondering if it is fine to times the volumetric flow with the density to get the mass flow rate at the fan.
Also since my model is cut in half would i have to times my mass flow rate by two?
Kind regards,
Syed
Sure, check here: Mass Flow Rate Fluids Flow Equation
And yes, if you are using half the model, you can double the mass flow rate to get the value for the whole inlet.
thank you for your help
