Geometry upload error
I am not able to upload a geometry and it keeps giving this error:
Can you tell me what the problem is?
Best
Tina
Can you get that stl file to a location where we can download it so we can have a look directly at the file?
You can find the geometry here:
https://drive.google.com/drive/folders/1Uq6YFTT60u1d9zXnOpgDXDWarG4IgT6D?usp=sharing
I’m having the problem I had here: Meshing Fail: Cell Zones Assigned Using Faces - #33 by DaleKramer and I’m trying to isolate the body causing the issues. I’ve concluded it is likely the chassis, hence the above model does not include the chassis. I was trying to upload it to see if all bodies show up as separate volumes, for me to conclude the chassis is indeed the problem and needs to be redone.
Hi, I need help. this error message appear when i try to upload the geometry
Hi there, what file format are you using?
Make sure to try STEP or Parasolid instead :slight_smile:
