Is there a method to alter the speed (i.e frames per second) at which an animation is played and to pause it on a particular frame?
Hi Roy!
Quite simple, you can find that option next to the play buttons (in red)
Hope that helps!
Could be that you turned them off Roy, could you try my quickfix for this?
\rightarrow Missing Toolbar in PP
Let me know if that helps!
It worked, thanks
